system.file.openFile - Several file extensions?
Is it possible to call system.file.openFile() allowing the user to select more than one type of file extension?
In my case i want the user to be able to select file types .JPG, .JPEG and .PNG
Currently, no. But here is the link to the entry on the feedback forum.
https://ideas.inductiveautomation.com/ignition-features-and-ideas/p/systemfileopenfile-add-the-ability-to-specify-multiple-file-extensions-for-filet
It’s not possible through the system function directly, unfortunately. Untested workaround solution:
from com.inductiveautomation.ignition.client.script import ClientFileUtilities
def openFiles(desc, *extensions):
	filechooser = ClientFileUtilities.getChooser(0, desc, *extensions)
	filechooser.setMultiSelectionEnabled(True)
	if filechooser.showOpenDialog(None) is not None:
		return [file.getPath() for file in filechooser.getSelectedFiles()]
def openFile(desc, *extensions):
		return filechooser.getSelectedFile().getPath()
# imageFiles = openFiles("Image (JPG, JPEG, PNG)", "jpg", "jpeg", "png")
# imageFile = openFile("Image (JPG, JPEG, PNG)", "jpg", "jpeg", "png")
@paul-griffith, your code works as expected. One thing I noticed is when users click cancel it still returns the selected file paths. Any idea how I could get it to return None when a user selects files and then decides to cancel?
@code_skin
can probably be changed to
	if filechooser.showOpenDialog(None) == 0:
where 0 is the ‘magic number’ representing javax.swing.JFileChooser#APPROVE_OPTION; see the constant field values reference: https://docs.oracle.com/javase/7/docs/api/constant-values.html#javax.swing.JFileChooser.APPROVE_OPTION
