System.gui. in multimonitor problems
I have a big complain about this client function in multimonitor full-size clients .mesaageBox and others. Is well know that this “popus” will display always at the default monitor producing some confusion for operators. Not only this function, also the component “popup calendar” also shows inconsistency in where display if using multimonitor. It would be nice to have an extra parameter to this function where “screen” could be an optional parameter.
I’m so anxious to see this finally getting fix.
Best regards to Inductive team.
I assume version 8 vision? It’s a known bug. If you can run in windowed mode it should work, fullscreen mode, for whatever reason, has the issue.
Not sure when it will be fixed, I’m waiting for a fix as well. Wish they would get it fixed.
Hope the same
