Good afternoon.
In Ignition 8.0.14, I have created a container and I have inserted an instance of a template at the bottom.
I have configured the layout of the template instance so that when resizing the container, the template always stays at the bottom of the container.
Also, I have programmed two buttons: “+” button to reset the container height and “-” button to “collapse” container.
"+" button actionPerformed:
"-" button actionPerformed:
But when I press the “-” button, the template disappears and is outside the container, instead of holding its position at the bottom
On the other hand, if I change the container size manually from the designer, the template is perfectly repositioned.
Best Regards.
