system.historian.queryRawPoints returns data outside of bounds
When using the new system.historian.queryRawPoints function, I'm gettting return data which is outside of the ending boundary. I have includeBounds set to false in the function call.
Here is the function call:
  LOGGER.info("  start     : '{}'".format(start))
  LOGGER.info("  end       : '{}'".format(end))
  query_results = system.historian.queryRawPoints(tag_paths, start, end, includeBounds=False)
  LOGGER.info("Raw query returned '{}' rows".format(len(query_results)))
  LOGGER.info("First Data Point Timestamp: '{}'".format(query_results[0][0]))
  LOGGER.info("Last Data Point Timestamp: '{}'".format(query_results[-1][0]))
Here is the console output:
11:05:26.414 [AWT-EventQueue-0] INFO Scripting-Utils.History.HistoryUtils --   start     : 'Fri Feb 27 00:00:00 EST 2026'
11:05:26.415 [AWT-EventQueue-0] INFO Scripting-Utils.History.HistoryUtils --   end       : 'Thu Mar 05 23:59:00 EST 2026'
11:05:26.542 [AWT-EventQueue-0] INFO Scripting-Utils.History.HistoryUtils -- Raw query returned '8408' rows
11:05:26.542 [AWT-EventQueue-0] INFO Scripting-Utils.History.HistoryUtils -- First Data Point Timestamp: 'Sat Feb 28 10:39:39 EST 2026'
11:05:26.543 [AWT-EventQueue-0] INFO Scripting-Utils.History.HistoryUtils -- Last Data Point Timestamp: 'Fri Mar 06 08:42:22 EST 2026'
Am I missing something / doing something wrong? I am on Ignition 8.3.5-Snapshot which I realize is meant to be for testing purposes but wanted to flag this.
Hey Zach, we actually fixed this bug pretty recently on March 2nd. Could you double check your build version and upgrade if it’s older than that?
Hey apadilla, I believe I upgraded? I'm still seeing the issue with data from outside the end boundary.
The changelog topic has versions listed like this: Nightly Changelog: 8.3.5*-b20260306
On my gateway webpage, I see I'm on version 8.3.5-SNAPSHOT (b2026030620)
I don't see any exact matches for build b2026030620. Am I on the most recent version?
I’m encountering the exact same issue on 8.3.3 and 8.3.4 (nightlies aren't an option for me). The issue also exists with the Tag History binding screen when pulling data in the asStored format – this is what led me to debugging with the system.historian.queryRawPoints (it also exists with the deprecated system.tag.queryTagHistory). The Tag History binding screen was what led me to debug with the script functions.
In my scenario, I’m trying to pull real-time data while running the Core Historian for use in a SparkLine or Time Series Chart. It definitely looked like a UTC time zone conversion issue, but even with that, it didn’t make much sense, since my offset is -7 and the seed is about 6 hours off.
end = system.date.now()
start = system.date.addMinutes(end, -60)
path = ['[default]mytagpath']
print end
print start
system.historian.queryRawPoints(path, start, end)
Thu Mar 19 20:29:37 PDT 2026
Thu Mar 19 19:29:37 PDT 2026
[[Thu Mar 19 19:55:15 PDT 2026, 78.0], [Thu Mar 19 20:38:11 PDT 2026, 76.0], [Thu Mar 19 20:38:14 PDT 2026, 58.0], [Fri Mar 20 02:25:25 PDT 2026, 75.0]]
If you look at the seed being included, it’s in the future, and on top of that, it isn’t even a correct seed value (it should be 58.0) – it looks like it matches this entry instead (which is outside of the time period. [Thu Mar 19 19:25:25 PDT 2026, 75.0]. This value does have a -7 hour offset.
I also encountered a different bug when working with the aggregation tag history binding, where I’m getting 0 values between the initial time (doesn’t matter if its time or # of points) and the first valid data point. Depending on the aggregation mode, some of these zero values are actually flagged as good.
Essentially, any way of getting a live trend with the tag history binding with low sample rates gives me a bad trend.
As a heads up, support confirmed that this issue has been fixed in 8.3.5 (I have not personally tested it).
The 0 issue in aggregation modes has been confirmed as a bug and has been assigned an internal ticket.
Thanks for this post. We have seen the same issue:
"The 0 issue in aggregation modes has been confirmed as a bug and has been assigned an internal ticket."
Have you heard when this may be fixed?
None of the bugs I've submitted have ever gotten an ETA, just that they assigned internal tickets to address.
I have upgraded to 8.3.6 (b2026042713), but I am still encountering an error with system.historian.queryRawPoints.
Calling the function in the two cases below returns different data points:
start= system.date.parse('2026-04-30 23:55:00')
end = system.date.parse('2026-04-30 23:59:59')
system.historian.queryRawPoints([tag_path], start, end)
Returned values timestamps
Thu Apr 30 23:56:19 CEST 2026
Thu Apr 30 23:57:19 CEST 2026
Thu Apr 30 23:58:19 CEST 2026
Thu Apr 30 23:59:19 CEST 2026
Mon May 04 11:19:50 CEST 2026
end = system.date.parse('2026-05-01 00:00:59')
Fri May 01 00:00:19 CEST 2026
Fri May 01 00:01:19 CEST 2026
In the first case, the last datapoint returned is the current timestamp. It should be Fri May 01 00:00:19 CEST 2026
In the second case, the data is correct.
I think I can confirm this is still happening under 8.3.7:
start = system.date.parse('2026-05-18 13:01:00')
end = system.date.parse('2026-05-19 07:52:00')
data = system.historian.queryRawPoints([tagPath], start, end)
for row in data:
    print(row[0])
Mon May 18 15:37:40 CDT 2026
Wed May 20 17:13:25 CDT 2026
Where the second data point there is after the end date
