i try in client and designer
servers = system.opc.getServers()
if not servers:
print "No servers found"
else:
for server in servers:
print server
every time i received error
[quote]Traceback (most recent call last):
File “event:actionPerformed”, line 2, in
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.newGatewayException(GatewayInterface.java:322)
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.sendMessage(GatewayInterface.java:296)
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.sendMessage(GatewayInterface.java:253)
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.invoke(GatewayInterface.java:811)
at com.inductiveautomation.factorypmi.application.script.builtin.ClientOPCUtilities.getServersImpl(ClientOPCUtilities.java:42)
at com.inductiveautomation.ignition.common.script.builtin.AbstractOPCUtilities.getServers(AbstractOPCUtilities.java:96)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
at java.lang.reflect.Method.invoke(Unknown Source)
com.inductiveautomation.ignition.client.gateway_interface.GatewayException: com.inductiveautomation.ignition.client.gateway_interface.GatewayException: Error executing gateway function.
at org.python.core.Py.JavaError(Py.java:495)
at org.python.core.Py.JavaError(Py.java:488)
at org.python.core.PyReflectedFunction.__call__(PyReflectedFunction.java:188)
at com.inductiveautomation.ignition.common.script.ScriptManager$ReflectedInstanceFunction.__call__(ScriptManager.java:427)
at org.python.core.PyObject.__call__(PyObject.java:371)
at org.python.core.PyObject.__call__(PyObject.java:375)
at org.python.pycode._pyx9.f$0(<event:actionPerformed>:6)
at org.python.pycode._pyx9.call_function(<event:actionPerformed>)
at org.python.core.PyTableCode.call(PyTableCode.java:165)
at org.python.core.Py.runCode(Py.java:1275)
at com.inductiveautomation.ignition.common.script.ScriptManager.runCode(ScriptManager.java:568)
at com.inductiveautomation.factorypmi.application.binding.action.ActionAdapter.runActions(ActionAdapter.java:168)
at com.inductiveautomation.factorypmi.application.binding.action.ActionAdapter.invoke(ActionAdapter.java:265)
at com.inductiveautomation.factorypmi.application.binding.action.RelayInvocationHandler.invoke(RelayInvocationHandler.java:55)
at com.sun.proxy.$Proxy21.actionPerformed(Unknown Source)
at javax.swing.AbstractButton.fireActionPerformed(Unknown Source)
at javax.swing.AbstractButton$Handler.actionPerformed(Unknown Source)
at javax.swing.DefaultButtonModel.fireActionPerformed(Unknown Source)
at javax.swing.DefaultButtonModel.setPressed(Unknown Source)
at javax.swing.plaf.basic.BasicButtonListener.mouseReleased(Unknown Source)
at java.awt.Component.processMouseEvent(Unknown Source)
at javax.swing.JComponent.processMouseEvent(Unknown Source)
at java.awt.Component.processEvent(Unknown Source)
at java.awt.Container.processEvent(Unknown Source)
at java.awt.Component.dispatchEventImpl(Unknown Source)
at java.awt.Container.dispatchEventImpl(Unknown Source)
at java.awt.Component.dispatchEvent(Unknown Source)
at java.awt.LightweightDispatcher.retargetMouseEvent(Unknown Source)
at java.awt.LightweightDispatcher.processMouseEvent(Unknown Source)
at java.awt.LightweightDispatcher.dispatchEvent(Unknown Source)
at java.awt.Window.dispatchEventImpl(Unknown Source)
at java.awt.EventQueue.access$200(Unknown Source)
at java.awt.EventQueue$3.run(Unknown Source)
at java.security.ProtectionDomain$1.doIntersectionPrivilege(Unknown Source)
at java.awt.EventQueue$4.run(Unknown Source)
Caused by: com.inductiveautomation.ignition.client.gateway_interface.GatewayException: Error executing gateway function.
at org.python.core.PyReflectedFunction.call(PyReflectedFunction.java:186)
… 49 more
Caused by: java.lang.NullPointerException
at com.inductiveautomation.ignition.gateway.opc.OPCManagerImpl$ServerWrapper.getName(OPCManagerImpl.java:667)
at com.inductiveautomation.ignition.gateway.opc.OPCManagerImpl$3.compare(OPCManagerImpl.java:365)
at com.inductiveautomation.ignition.gateway.opc.OPCManagerImpl$3.compare(OPCManagerImpl.java:361)
at java.util.TimSort.countRunAndMakeAscending(null)
at java.util.TimSort.sort(null)
at java.util.Arrays.sort(null)
at java.util.Collections.sort(null)
at com.inductiveautomation.ignition.gateway.opc.OPCManagerImpl.getServers(OPCManagerImpl.java:361)
at com.inductiveautomation.ignition.gateway.servlets.gateway.functions.OPCSystem.getServers(OPCSystem.java:67)
at sun.reflect.GeneratedMethodAccessor318.invoke(null)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(null)
at java.lang.reflect.Method.invoke(null)
at com.inductiveautomation.ignition.gateway.servlets.gateway.AbstractGatewayFunction.invoke(AbstractGatewayFunction.java:176)
at com.inductiveautomation.ignition.gateway.servlets.Gateway.doPost(Gateway.java:369)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:707)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:790)
at com.inductiveautomation.ignition.gateway.bootstrap.MapServlet.service(MapServlet.java:85)
at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:696)
at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:526)
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:143)
at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:568)
at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:221)
at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1110)
at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:453)
at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:183)
at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1044)
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:141)
at org.eclipse.jetty.server.handler.HandlerList.handle(HandlerList.java:52)
at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:97)
at org.eclipse.jetty.server.Server.handle(Server.java:459)
at org.eclipse.jetty.server.HttpChannel.handle(HttpChannel.java:280)
at org.eclipse.jetty.server.HttpConnection.onFillable(HttpConnection.java:229)
at org.eclipse.jetty.io.AbstractConnection$1.run(AbstractConnection.java:505)
at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:607)
at org.eclipse.jetty.util.thread.QueuedThreadPool$3.run(QueuedThreadPool.java:536)
at java.lang.Thread.run(null)
Ignition v7.7.0 (b2014071516)
Java: Oracle Corporation 1.7.0_65
[/quote]
++++UPDATE++++++
After delete Faulted and disabled servers it works
