Can a name be auto-populated (such as date/time) into the system.print.createPrintJob function? This would allow the file to be saved without using the PrintDialog popup.
Unfortunately, no. However, if you are just trying to save a snapshot of a component to a file, you can create a BufferedImage of the desired resolution, use myComponent.paint(bufimage.getGraphics()) to render the component into the image, then use ImageIO to save the rendered image to a file.
Thanks @pturmel, would the resulting file have to be saved as an image type?
Yes. You might also investigate using Java’s PrintJob class yourself (a bit of a pain, iirc).
If you are just looking to print screen to a file you could use something like this.
We use it to email screenshots from the operators to support.
def saveScreenshot(twindow):
from java.io import File
from java.awt.image import BufferedImage
from javax.imageio import ImageIO
from java.awt import Robot
from java.awt import Rectangle
from java.awt import Toolkit
import system
problem = system.gui.inputBox('Enter a short description of the problem and click OK','Problem Report')
home = system.util.getProperty("user.home")
BufferedImage = Robot().createScreenCapture(Rectangle(Toolkit.getDefaultToolkit().getScreenSize()))
temp = File(home + "/Documents/" + twindow + ".png");
temp.mkdirs()
ImageIO.write(BufferedImage, "png", temp)
It will create a png screenshot in the users home directory.
You can modify it to save wherever with whatever name you want.
