Hello there,
I’m new at Ignition, so what I’m trying to do is maybe a wrong approach but I can’t find another way.
I have a sequence where at some point I save a report with the save option of the system.report.executeAndDistribute function:
Path = "D:\\Program files2\\Ignition_install\\REPORTS\\"
settings = {"path":Path, "fileName":Name, "format":"pdf"}
system.report.executeAndDistribute(path="LNG_COMP_REP_2", project=project, action="save", actionSettings=settings)
This is ok, the file is saved on the right place.
I also copy the report name to a memory tag and via a gateway tag change script I would like to print that latest report:
Lastreport = system.tag.readBlocking(['[SAMPLER_TAGS]SAMPLER/PROJECT/SAMPLING_STATUS/S1_Last_Report_Name'])[0].value
Reportpath = "D:\\Program files2\\Ignition_install\\REPORTS\\"+Lastreport
project = 'SAMPLER'
printer = 'IgnitionPrinter'
settings = {"primaryPrinterName":printer, "copies":1}
system.report.executeAndDistribute(path=Reportpath, project=project, action='print', actionSettings=settings)
But what ever I try I keep on getting the message “Report path D:\Program files2\Ignition_install\REPORTS\SAMPRPRT.pdf can not be found”
In the wrapper log the path name is good, if I put it in windows exporer the right file is opened.
I also have a file exporer and pdf viewer both show the correct report.
But with the tag change script it does not work.
Should I specify the path in another way or do something else?
I’m running Ignition designer 8.1.17 with Vision in trial mode, both gateway and designer are on the same PC.
I really would appreciate some help, thanks in advance.
