Ah. Thak you. That worked.
you can specify the provider in the parent path. [myprovider]. If you leave this off it defaults to the default provider.
The tag provider that Iām using is called āTestā and the OPC device is called āMy_testā.
Iāve tried both of the following items for the OPCItemPath
[Test]1.D1000
[My_test]1.D1000
It seems no matter what I put in there I get the following error:
[code]Traceback (most recent call last):
File āevent:actionPerformedā, line 1, in
File āmodule:shared.tagRenameā, line 41, in myMain
File āmodule:shared.tagRenameā, line 31, in buildTags
com.inductiveautomation.ignition.client.gateway_interface.GatewayException: com.inductiveautomation.ignition.client.gateway_interface.GatewayException: Tag provider ādefaultā not found.
caused by GatewayException: Tag provider ādefaultā not found.
caused by IllegalArgumentException: Tag provider ādefaultā not found.
Ignition v7.7.1 (b2014092209)
Java: Oracle Corporation 1.8.0_31
[/code]
you wouldnt use the tagprovider in the opc path, only the parent path.
