I’m implementing a dynamic chart, so I’m using system.tag.browseHistoricalTags to iterate throught it. Found out that if I have a UDT inside the tag provider without any folder holding it
def browse(path='histprov:DB:/drv:server:tagprovider:/tag:'):
for result in system.tag.browseHistoricalTags(path).getResults():
print result
if result.hasChildren():
browse(str(result.getPath()))
browse()
will return
Result[displayPath=null, path=histprov:DB:/drv:server:provider:/tag:/anyfolder, hasChildren=true, type=null]
File "<input>", line 6, in <module>
File "<input>", line 5, in browse
File "<input>", line 2, in browse
TypeError: 'NoneType' object is not iterable
If I put the UDT Instances inside a folder the code runs without any problem.
