I have a couple of client tags under SECSGEM/Connection folder of the Client tags.
tags = system.tag.browseTags("[Client]SECSGEM/Connection")
for tag in tags:
print tag.name
When I tried to execute the above script in the playground, I got this error.
com.inductiveautomation.ignition.client.gateway_interface.GatewayException: com.inductiveautomation.ignition.client.gateway_interface.GatewayException: Unable to list tags, provider "Client" not found
caused by GatewayException: Unable to list tags, provider "Client" not found
caused by RuntimeException: Unable to list tags, provider "Client" not found
When I remove [Client] from the path, it doesn’t do anything.
If I don’t pass a path, I get correct tags list from its tag provider.
Does anyone know what I’m doing it wrong? I can read and write value from/to client tag but why I can’t browse doesn’t work?
My gateway is 7.7.2 (b2014121709)
Java 8 update 11
