Ignition 8.0.12
I’m trying to script changes to several tags by copying the configuration of one tag to all the others.
When I use the old system.tag.editTag command/syntax, it works, but it won’t accept several of the attributes I want to set, e.g., HistoricalDeadband, HistoryMaxAge).
When I use system.tag.configure in the following manner:
orig = '[Source]foobar_path'
configs = system.tag.getConfiguration(orig, True)
results = system.tag.browse(path = '[Source]foo_path', filter = {'tagType':'folder'})
for result in results.getResults():
name = result['name']
parentPath = '[Source]foo_path/'+ name + '/bar_path'
system.tag.configure(parentPath, configs, "o")
I get [Bad_AccessDenied].
What am I doing wrong?
