system.tag.editTag Cannot edit dataType
Ignition v7.9.10 (b2018112821)
Win 10
I am having issues trying to change the data type of a tag so I created a temporary one to experiment with. Below is the code and error. I tried both integer and string. Can someone point me in the right direction?
Code:
system.tag.editTag(tagPath = "[default]/Test/TestTag1",attributes={"dataType":"Float4"})
09:20:04.036 [AWT-EventQueue-2] ERROR com.inductiveautomation.factorypmi.application.binding.action.ActionAdapter - <HTML>Error executing script for event:&nbsp;<code><b>actionPerformed</b></code><BR>on component:&nbsp;<code><b>btnChangeDatatype 2</b></code>.
com.inductiveautomation.ignition.common.script.JythonExecException: Traceback (most recent call last):
  File "<event:actionPerformed>", line 1, in <module>
	at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.newGatewayException(GatewayInterface.java:341)
	at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.sendMessage(GatewayInterface.java:315)
	at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.sendMessage(GatewayInterface.java:268)
	at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.invoke(GatewayInterface.java:894)
	at com.inductiveautomation.factorypmi.application.script.builtin.ialabs.IALabsTagFunctions.editTagImpl(IALabsTagFunctions.java:59)
	at com.inductiveautomation.ignition.common.script.builtin.ialabs.AbstractIALabsTagFunctions.editTag(AbstractIALabsTagFunctions.java:58)
	at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
	at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
	at java.lang.reflect.Method.invoke(Unknown Source)
com.inductiveautomation.ignition.client.gateway_interface.GatewayException: com.inductiveautomation.ignition.client.gateway_interface.GatewayException: Attribute 'dataType' is invalid or value is an incorrect data type
	at org.python.core.Py.JavaError(Py.java:495)
	at org.python.core.Py.JavaError(Py.java:488)
	at org.python.core.PyReflectedFunction.__call__(PyReflectedFunction.java:188)
	at com.inductiveautomation.ignition.common.script.ScriptManager$ReflectedInstanceFunction.__call__(ScriptManager.java:431)
	at org.python.core.PyObject.__call__(PyObject.java:320)
	at org.python.pycode._pyx203.f$0(<event:actionPerformed>:1)
	at org.python.pycode._pyx203.call_function(<event:actionPerformed>)
	at org.python.core.PyTableCode.call(PyTableCode.java:165)
	at org.python.core.Py.runCode(Py.java:1275)
	at com.inductiveautomation.ignition.common.script.ScriptManager.runCode(ScriptManager.java:636)
	at com.inductiveautomation.factorypmi.application.binding.action.ActionAdapter.runActions(ActionAdapter.java:180)
	at com.inductiveautomation.factorypmi.application.binding.action.ActionAdapter.invoke(ActionAdapter.java:271)
	at com.inductiveautomation.factorypmi.application.binding.action.RelayInvocationHandler.invoke(RelayInvocationHandler.java:57)
	at com.sun.proxy.$Proxy33.actionPerformed(Unknown Source)
	at javax.swing.AbstractButton.fireActionPerformed(Unknown Source)
	at javax.swing.AbstractButton$Handler.actionPerformed(Unknown Source)
	at javax.swing.DefaultButtonModel.fireActionPerformed(Unknown Source)
	at javax.swing.DefaultButtonModel.setPressed(Unknown Source)
	at javax.swing.plaf.basic.BasicButtonListener.mouseReleased(Unknown Source)
	at java.awt.Component.processMouseEvent(Unknown Source)
	at javax.swing.JComponent.processMouseEvent(Unknown Source)
	at java.awt.Component.processEvent(Unknown Source)
	at java.awt.Container.processEvent(Unknown Source)
	at java.awt.Component.dispatchEventImpl(Unknown Source)
	at java.awt.Container.dispatchEventImpl(Unknown Source)
	at java.awt.Component.dispatchEvent(Unknown Source)
	at java.awt.LightweightDispatcher.retargetMouseEvent(Unknown Source)
	at java.awt.LightweightDispatcher.processMouseEvent(Unknown Source)
	at java.awt.LightweightDispatcher.dispatchEvent(Unknown Source)
	at java.awt.Window.dispatchEventImpl(Unknown Source)
	at java.awt.EventQueue.access$500(Unknown Source)
	at java.awt.EventQueue$3.run(Unknown Source)
	at java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(Unknown Source)
	at java.awt.EventQueue$4.run(Unknown Source)
Caused by: org.python.core.PyException: Traceback (most recent call last):
	... 51 common frames omitted
Caused by: com.inductiveautomation.ignition.client.gateway_interface.GatewayException: Attribute 'dataType' is invalid or value is an incorrect data type
	at org.python.core.PyReflectedFunction.__call__(PyReflectedFunction.java:186)
	... 48 common frames omitted
Caused by: com.inductiveautomation.ignition.client.gateway_interface.GatewayResponse$GatewayThrowable: Attribute 'dataType' is invalid or value is an incorrect data type
	at com.inductiveautomation.ignition.gateway.script.ialabs.IALabsTagFunctions.__editTags(IALabsTagFunctions.java:788)
	at com.inductiveautomation.ignition.gateway.script.ialabs.IALabsTagFunctions.editTagImpl(IALabsTagFunctions.java:684)
	at com.inductiveautomation.ignition.gateway.servlets.gateway.functions.IALabs.editTag(IALabs.java:175)
	at sun.reflect.NativeMethodAccessorImpl.invoke(null)
	at sun.reflect.DelegatingMethodAccessorImpl.invoke(null)
	at java.lang.reflect.Method.invoke(null)
	at com.inductiveautomation.ignition.gateway.servlets.gateway.AbstractGatewayFunction.invoke(AbstractGatewayFunction.java:208)
	at com.inductiveautomation.ignition.gateway.servlets.Gateway.doPost(Gateway.java:404)
	at javax.servlet.http.HttpServlet.service(HttpServlet.java:707)
	at javax.servlet.http.HttpServlet.service(HttpServlet.java:790)
	at com.inductiveautomation.ignition.gateway.bootstrap.MapServlet.service(MapServlet.java:85)
	at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:837)
	at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:583)
	at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:143)
	at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:548)
	at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:226)
	at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1160)
	at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:511)
	at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:185)
	at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1092)
	at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:141)
	at org.eclipse.jetty.server.handler.HandlerList.handle(HandlerList.java:52)
	at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:134)
	at org.eclipse.jetty.server.Server.handle(Server.java:518)
	at org.eclipse.jetty.server.HttpChannel.handle(HttpChannel.java:308)
	at org.eclipse.jetty.server.HttpConnection.onFillable(HttpConnection.java:244)
	at org.eclipse.jetty.io.AbstractConnection$ReadCallback.succeeded(AbstractConnection.java:273)
	at org.eclipse.jetty.io.FillInterest.fillable(FillInterest.java:95)
	at org.eclipse.jetty.io.SelectChannelEndPoint$2.run(SelectChannelEndPoint.java:93)
	at org.eclipse.jetty.util.thread.strategy.ExecuteProduceConsume.produceAndRun(ExecuteProduceConsume.java:246)
	at org.eclipse.jetty.util.thread.strategy.ExecuteProduceConsume.run(ExecuteProduceConsume.java:156)
	at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:654)
	at org.eclipse.jetty.util.thread.QueuedThreadPool$3.run(QueuedThreadPool.java:572)
	at java.lang.Thread.run(null)
Since your in 7.9 you need to change “dataType” to “Datatype”. In 8.0 the way you showed it is right but in the 7.9 manual it is “Datatype”
These are the combinations I have tried, all with the same error.
system.tag.editTag(tagPath = "[default]/Test/TestTag1",attributes={"dataType":4})
system.tag.editTag(tagPath = "[default]/Test/TestTag1",attributes={"Datatype":"Float4"})
system.tag.editTag(tagPath = "[default]/Test/TestTag1",attributes={"Datatype":4})
Apparently, I can edit other attributes except data type. Is this reproducible on your systems?
I never tried changing the datatype with a script before. I tried real quick with a test tag and it didn’t work. I’m assuming they don’t allow. Personally I haven’t run into a situation where I needed to change the datatype dynamically. What are you trying to do with it that you want to change it by script?
I have been reviewing some older projects at one of our plants and from one of my reports there are about 285 tags defined as a string when they should be defined as a float. This was initially noticed when a user said they could not display a tag on the chart.
I created a few screens to analyze the historian tags and and compare to the internal tag configuration. If discrepancies are found I allow the option of changing the datatype. Once this is done I perform an update query to set the value in the ‘floatvalue’ column for each of the historian tables.
Everything is done except the ability to change the datatype.Currently, I run the project along side the designer and change the tag manually in the designer.
system.tag.editTag(tagPath = "[default]/Test/TestTag1",attributes={"DataType":"Float4"})
I’m not sure if you tried what camatt3 said. I think when I tried it, I tried it that way once with no luck but I’m not positive. If it doesn’t work, you could consider using a combination of system.tag.browseConfiguration, system.tag.removeTag and system.tag.addTag. With the browseConfiguration you should be able to extract all of the tag information you need to build a new tag setup the way you want. Then you use the removeTag function to remove the tag you don’t want anymore, then recreate the tag using the addTag function. The only issue I see is since you will be deleting and then readding the tag, I’m not sure how that would work with maintaining the historian. I would assume it would create a new ID for the new tag so you may have to do a little more in the database to keep everything linked after.
