system.tag.editTag unexpected behavior in try/except
Okay, so I’ve got it narrowed down pretty simple here. When changing tags I’d love a return value to let me know if it worked, but editTag doesn’t return anything so:
try:
	system.tag.editTag(tagPath='[default]This/doesnt/exist', overrides={"STATUS": {'Enabled':True}})
except:
	print( "didn't work" )
The tag doesn’t exist yet I get no error, whereas changing the tag provider
try:
	system.tag.editTag(tagPath='[deefoullt]Foo/bar/baz', overrides={"STATUS": {'Enabled':True}})
except:
will print “didn’t work”
I hate to go back and read each and every one to check for failure, that seems… not best practice way of handling things
Anyone else run into this?
Did you find a solution for this? I am running into the same problem with a gateway scoped script that isn’t throwing any error when system.tag.read("") is trying to read a tag that doesn’t exist.
For example:
try:
   tagValue = system.tag.read("Path/To/Machine%s/Tag" % (machineNo)).value
except:
   print 'error'
doesn’t print ‘error’ if the parameter machineNo ends up creating an invalid tag path.
This is quite problematic considering it is gateway scoped and i want to handle errors nicely in a logger or an alert somehow.
Found this thread to solve the problem:
http://forum.inductiveautomation.com/t/try-except-when-reading-tags/16179
Thanks for updating the thread! I know I never came to a conclusion at the time b/c I would have posted the answer, I just went on with my life lol
I’d like to think I could figure it out now, I had only been working in Ignition for a couple weeks when I made the OP
Cheers
