I want to export my tag configuration as a valid json object so I can mutate it by script. When I try to run the following, it inevitably bounces off of some custom class objects that come out of the configuration. Is there a "full string" valid JSON mechanism for extracting this information? I can go through the effort of "repairing" the object with some aggressive recursive string casting but if there is a first-party mechanism for this I would prefer it. The script console clearly has some extra decoration to handle these things gracefully but I want to edit the configuration externally.'
conf = system.tag.getConfiguration("[HMI]myProject", True)
myJson = json.dumps(conf) # this inevitably bounces off something like Boolean or TagPath etc.
Thanks! Thats the kind of thing I was hoping to have exist.
myJson = system.util.jsonEncode(system.tag.getConfiguration("[HMI]", True))
>>> Traceback (most recent call last):
File "<input>", line 68 in <module>
RuntimeError: maximum recursion depth exceeded (Java StackOverflowError)
but uh oh -- it's bricked my script console.
I've tried shrinking the depth on that configuration and it does not work at what I would consider to be an exceptionally reasonably sized configuration.
What about system.tag.exportTags instead?
Oh, I've seen that. Some kind of circular reference.
Try my Integration Toolkit's system.util.orderedcopy(). It tracks references and copies the loops correctly.
(But exportTags is almost certainly better.)
That sounds like something I'd want! Thanks.
I tried it:
>>> conf = system.tag.getConfiguration("[HMI]", True)
>>> system.tag.exportTags(None, conf, True)
Java Traceback:
File "<input>", line 68, in <module>
at com.inductiveautomation.ignition.common.script.builtin.AbstractTagUtilities.exportTags(AbstractTagUtilities.java:571)
java.lang.ClassCastException: java.lang.ClassCastException: class com.inductiveautomation.ignition.common.config.PyTagDictionary cannot be cast to class java.lang.String (com.inductiveautomation.ignition.common.config.PyTagDictionary is in unnamed module of loader java.net.URLClassLoader @1adaa42b; java.lang.String is in module java.base of loader 'bootstrap')
at org.python.core.Py.JavaError(Py.java:545)
at org.python.core.Py.JavaError(Py.java:536)
at org.python.core.PyReflectedFunction.__call__(PyReflectedFunction.java:192)
at com.inductiveautomation.ignition.common.script.ScriptManager$ReflectedInstanceFunction.__call__(ScriptManager.java:553)
at org.python.core.PyObject.__call__(PyObject.java:494)
at org.python.core.PyObject.__call__(PyObject.java:498)
at org.python.pycode._pyx405.f$0(<input>:68)
at org.python.pycode._pyx405.call_function(<input>)
at org.python.core.PyTableCode.call(PyTableCode.java:173)
at org.python.core.Py.runCode(Py.java:1703)
at org.python.core.Py.exec(Py.java:1747)
at org.python.util.PythonInterpreter.exec(PythonInterpreter.java:277)
at org.python.util.InteractiveInterpreter.runcode(InteractiveInterpreter.java:130)
at com.inductiveautomation.ignition.designer.gui.tools.jythonconsole.JythonConsole$ConsoleWorker.doInBackground(JythonConsole.java:628)
at com.inductiveautomation.ignition.designer.gui.tools.jythonconsole.JythonConsole$ConsoleWorker.doInBackground(JythonConsole.java:616)
at java.desktop/javax.swing.SwingWorker$1.call(Unknown Source)
at java.desktop/javax.swing.SwingWorker.run(Unknown Source)
Caused by: java.lang.ClassCastException: class com.inductiveautomation.ignition.common.config.PyTagDictionary cannot be cast to class java.lang.String (com.inductiveautomation.ignition.common.config.PyTagDictionary is in unnamed module of loader java.net.URLClassLoader @1adaa42b; java.lang.String is in module java.base of loader 'bootstrap')
at org.python.core.PyReflectedFunction.__call__(PyReflectedFunction.java:190)
... 19 more
second argument is not whatever you get from getConfiguration...
Ah that's true, it needs to be a list of paths. Lets try again!
myJson = system.tag.exportTags(None, ["[HMI]"], True)
It works! At least it returns an object that I can write to a file myself; trying to write directly takes my linux path (running containerized) and seems to have flipped it to a C:\{my path with / -> \} path without my consent. i.e.
>>> print(system.tag.exportTags("/myFileSystem/tags.json", ["[HMI]"], True))
C:\myFileSystem\tags.json
I'm guessing that method hasn't been updated to support containerized/linux environments?
(Addional QOL: please consider adjusting all of the scripting functions that take lists of things to auto-list a single non-list argument) if not isinstance(arg, list): arg = list(arg))
You're running this in the Designer Script console, so I'm not sure your containerized environment is relevant. You're on Windows, so you get a Windows path. It wrote to a file on the host running the Designer.
Also this seems to be poorly documented and only inferred from an example, but if you omit the filePath parameter it'll just return the export contents:
# Exports the entire tag provider named "default" as a string, and
# returns the string to a "tags" variable.
tags = system.tag.exportTags(tagPaths = ["[default]"])
Ah yes my old Achilles heel. My gateway message helpers that I use to write files managed to have me forget about this for awhile. I used the non-pathed option to get the data and write it to my real filesystem using that, but spaced on the direct write.
