[IGN-13157]System tag provider disabled after gateway restore
I think the issue may have something to do with "restore disabled" being a bit wonky right now: [IGN-14380]The Gateway has failed to succesfully start - #6 by paul-griffith
If you look on the Gateway filesystem at $IGNITION/data/config/resources/core/ignition/tag-provider/System/resource.json does the attributes object in that file have a "enabled" : false entry?
