Hi!.
I'm testing the "system.tag.query()" function for a Remote Tag Provider, but it always returns 0. Instead, system.tag.browse() works fine.
Hi!.
Your condition.attributes query might be limiting the results, if you remove the attributes portion, does it give you the results you expect?
I was wrong. I wasn't pointed at my remote provider when testing initially. I'm seeing the same result
@pturmel can you help me?
No idea.
Is the gateway hosting your remote provider new enough to support system.tag.query? The code certainly implies it should work to remote gateways.
You should probably take this to support.
Hello.
The problem is that the version of Ignition Edge is 8.1.17.
Thank you.
