As Phil said, I wouldn’t rely on an undocumented/unintended function staying.
If you want to guarantee column names remain consistent across datasets and updates, you should use the aliases parameter in the system.tag.queryTagCalculations(), that functionality is documented and not likely to change anytime soon.
This function will always return 1 row for each tagPath sent. Depending on what calculations you ask it to preform you may get a different amount of columns. So long as you always ask for the same calculations you can predict the resulting size of the returned dataset.
I don’t believe you can rely on a set order, each row will be identified by the tagPath or alias you have assigned, per the parameters.
(1) if i cannot rely on using an undocumented method of getting back a full tag path and (2) if I cannot rely on the original method returning the data back in a specific order… how can I use this function to effectively poll 1000’s of tags on any one request and process them into another dataset/list?
What exactly are you trying to do? I'm not sure what you mean by process them into another dataset/list?
From the manual:
This is useful when you wish to aggregate Tag history collected over a period of time into a single value per aggregate. If you want multiple values aggregated to a single time slice (i.e., hourly aggregates for the same Tag over an 8 hour period) consider using system.tag.queryTagHistory
On top of that, databases do not have a guaranteed order, by design. That is in fact the entire reason of the Order By clause. Instead the data generally has a "key" which allows for identifying the data which is related. In the case of system.tag.queryTagCalculations this is done by looking at the aggregate. You can then look through the dataset and pull the pertinent information.
I have a database table that hold my tag names, configuration, paths, etc., that I am pulling into a list of lists (to include additional process/business data). While looping through this list, I am creating a separate tag list for use with this function. Call the function into a dataset object. Then I am looping through my list of lists and polling the results from this function by index to get its value for processing it further from there.
I need to be able to depend on either its correct indexing location or a full tag path to lookup.
