I have a test gateway that I am using to see how my one of my report scripts run with production gateway data. This test gateway is copy of a production gateway, so all its tags were imported with the project as well as the tag history.
When I run System.tag.queryTagHistory() to test the data grab:
start = system.date.parse('April 1, 2025 00:00','MMMM dd, yyyy hh:mm')
end = system.date.parse('April 30, 2025 00:00','MMMM dd, yyyy hh:mm')
path = '[EHS]EHS/B2 Permit/Incoming Water/CH00243/Total'
history =system.tag.queryTagHistory([path],startDate=start, endDate= end, ignoreBadQuality=True,noInterpolation=True)
print(history.getRowCount())
I get a row count of 0.
However, when I search for the same tag path '[EHS]EHS/B2 Permit/Incoming Water/CH00243/Total' in the sqlth_te table I find 3 tags:
I then go and check that see if any of the IDs associated to the tagpath have data in the table sqlt_data_1_2025_04 . Of the 3 IDs associated with the tag path, only one has data in the table, this being ID 1951.
So I am sure the data is present in the system, and so something is happening when I try to grab it.
This situation is the same across all the tags. There are 3 IDs per tag path, with only one of them, the second one, having data.
Things I've tried to fix this:
Setting the newest ID to retired in the
sqlth_tetable so that the second tag will be referenced when calling thesystem.tag.queryTagHistory(). This did nothing. -
Change the SCID of the row that has the ID corresponding to data to the SCID that corresponds the newest ID for the tag of interest. This did nothing.
Change the SCID of the row that corresponds the newest ID to the SCID that corresponds the row that contains the ID that has data in
sqlt_data_1_2025_04. This did nothing.
I am not sure where to go from this point. I was attempting to use this as reference: Ignition Database Table Reference
so that I could manipulate the system to access the correct ID and/or partition for a tag, but I can't seem to figure it out.
Any suggestions? Thank you
