system.tag.queryTagHistory: Read timed out - Communications link failure
I’ve been working on a window to allow a user to do custom query and export of historical data (there did not seem to be any existing component for this, let me know if I missed it). Basically I have added components and scripting which allow selection of tags and determination of the other parameters required to execute a scripted query with system.tag.queryTagHistory. Some of the queries can run long and I found that the query was timing out with error “Read timed out”… No problem, increased the timeout parameter that I fed to system.tag.queryTagHistory (greater than the 60000 ms default). However now I find that I get a different error, exactly at the two minute mark indicating Communications Link Failure
com.inductiveautomation.ignition.client.gateway_interface.GatewayException: Communications link failure
The last packet successfully received from the server was 120,001 milliseconds ago. The last packet sent successfully to the server was 120,000 milliseconds ago.
Given the this happens right at two minutes I figure that this is due to some other configured timeout but I have not been able to to figure out how to extend this. I can get the query to complete in less than two minutes by selecting a much smaller time period but I need the query to cover a larger time period to satisfy my objectives.
Has anyone run into this problem and found a resolution?
Error screenshot:
Error Details:
  File "<event:actionPerformed>", line 132, in <module>
	at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.newGatewayException(GatewayInterface.java:341)
	at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.sendMessage(GatewayInterface.java:315)
	at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.runTagHistoryQuery(GatewayInterface.java:726)
	at com.inductiveautomation.ignition.client.script.ClientTagUtilities.queryTagHistoryImpl(ClientTagUtilities.java:328)
	at com.inductiveautomation.ignition.common.script.builtin.AbstractTagUtilities.queryTagHistory(AbstractTagUtilities.java:537)
	at sun.reflect.GeneratedMethodAccessor478.invoke(Unknown Source)
	at java.lang.reflect.Method.invoke(Unknown Source)
com.inductiveautomation.ignition.client.gateway_interface.GatewayException: com.inductiveautomation.ignition.client.gateway_interface.GatewayException: Communications link failure
	at org.python.core.Py.JavaError(Py.java:495)
	at org.python.core.Py.JavaError(Py.java:488)
	at org.python.core.PyReflectedFunction.__call__(PyReflectedFunction.java:188)
	at com.inductiveautomation.ignition.common.script.ScriptManager$ReflectedInstanceFunction.__call__(ScriptManager.java:431)
	at org.python.core.PyObject.__call__(PyObject.java:320)
	at org.python.pycode._pyx883.f$0(<event:actionPerformed>:159)
	at org.python.pycode._pyx883.call_function(<event:actionPerformed>)
	at org.python.core.PyTableCode.call(PyTableCode.java:165)
	at org.python.core.Py.runCode(Py.java:1275)
	at com.inductiveautomation.ignition.common.script.ScriptManager.runCode(ScriptManager.java:636)
	at com.inductiveautomation.factorypmi.application.binding.action.ActionAdapter.runActions(ActionAdapter.java:180)
	at com.inductiveautomation.factorypmi.application.binding.action.ActionAdapter.invoke(ActionAdapter.java:271)
	at com.inductiveautomation.factorypmi.application.binding.action.RelayInvocationHandler.invoke(RelayInvocationHandler.java:57)
	at com.sun.proxy.$Proxy18.actionPerformed(Unknown Source)
	at javax.swing.AbstractButton.fireActionPerformed(Unknown Source)
	at javax.swing.AbstractButton$Handler.actionPerformed(Unknown Source)
	at javax.swing.DefaultButtonModel.fireActionPerformed(Unknown Source)
	at javax.swing.DefaultButtonModel.setPressed(Unknown Source)
	at javax.swing.plaf.basic.BasicButtonListener.mouseReleased(Unknown Source)
	at java.awt.Component.processMouseEvent(Unknown Source)
	at javax.swing.JComponent.processMouseEvent(Unknown Source)
	at java.awt.Component.processEvent(Unknown Source)
	at java.awt.Container.processEvent(Unknown Source)
	at java.awt.Component.dispatchEventImpl(Unknown Source)
	at java.awt.Container.dispatchEventImpl(Unknown Source)
	at java.awt.Component.dispatchEvent(Unknown Source)
	at java.awt.LightweightDispatcher.retargetMouseEvent(Unknown Source)
	at java.awt.LightweightDispatcher.processMouseEvent(Unknown Source)
	at java.awt.LightweightDispatcher.dispatchEvent(Unknown Source)
	at java.awt.Window.dispatchEventImpl(Unknown Source)
	at java.awt.EventQueue.access$500(Unknown Source)
	at java.awt.EventQueue$3.run(Unknown Source)
	at java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(Unknown Source)
	at java.awt.EventQueue$4.run(Unknown Source)
Caused by: com.inductiveautomation.ignition.client.gateway_interface.GatewayException: Communications link failure
	at org.python.core.PyReflectedFunction.__call__(PyReflectedFunction.java:186)
	... 48 more
Caused by: com.mysql.jdbc.exceptions.jdbc4.CommunicationsException: Communications link failure
	at sun.reflect.GeneratedConstructorAccessor162.newInstance(null)
	at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(null)
	at java.lang.reflect.Constructor.newInstance(null)
	at com.mysql.jdbc.Util.handleNewInstance(Util.java:411)
	at com.mysql.jdbc.SQLError.createCommunicationsException(SQLError.java:1117)
	at com.mysql.jdbc.MysqlIO.reuseAndReadPacket(MysqlIO.java:3603)
	at com.mysql.jdbc.MysqlIO.reuseAndReadPacket(MysqlIO.java:3492)
	at com.mysql.jdbc.MysqlIO.checkErrorPacket(MysqlIO.java:4043)
	at com.mysql.jdbc.MysqlIO.sendCommand(MysqlIO.java:2503)
	at com.mysql.jdbc.MysqlIO.sqlQueryDirect(MysqlIO.java:2664)
	at com.mysql.jdbc.ConnectionImpl.execSQL(ConnectionImpl.java:2794)
	at com.mysql.jdbc.PreparedStatement.executeInternal(PreparedStatement.java:2155)
	at com.mysql.jdbc.PreparedStatement.executeQuery(PreparedStatement.java:2322)
	at org.apache.commons.dbcp.DelegatingPreparedStatement.executeQuery(DelegatingPreparedStatement.java:93)
	at com.inductiveautomation.ignition.gateway.datasource.SRConnectionWrapper$SRPreparedStatement.executeQuery(SRConnectionWrapper.java:948)
	at com.inductiveautomation.gateway.tags.history.query.DatasourceQueryExecutor.advancePartition(DatasourceQueryExecutor.java:1048)
	at com.inductiveautomation.gateway.tags.history.query.DatasourceQueryExecutor.primeRead(DatasourceQueryExecutor.java:969)
	at com.inductiveautomation.ignition.gateway.sqltags.history.query.AbstractHistoryLoader.startReading(AbstractHistoryLoader.java:104)
	at com.inductiveautomation.ignition.gateway.sqltags.history.query.AggregateHistoryQueryExecutor.startReading(AggregateHistoryQueryExecutor.java:85)
	at com.inductiveautomation.ignition.gateway.sqltags.history.query.HistoryWriter.readData(HistoryWriter.java:301)
	at com.inductiveautomation.ignition.gateway.sqltags.history.query.HistoryWriter.execute(HistoryWriter.java:230)
	at com.inductiveautomation.ignition.gateway.sqltags.SQLTagsManagerImpl.queryHistory(SQLTagsManagerImpl.java:1297)
	at com.inductiveautomation.ignition.gateway.project.ProjectSettingsCache$ProjectDefaultTagManagerFacade.queryHistory(ProjectSettingsCache.java:673)
	at com.inductiveautomation.ignition.gateway.servlets.gateway.functions.QueryTagHistory.invoke(QueryTagHistory.java:96)
	at com.inductiveautomation.ignition.gateway.servlets.Gateway.doPost(Gateway.java:404)
	at javax.servlet.http.HttpServlet.service(HttpServlet.java:707)
	at javax.servlet.http.HttpServlet.service(HttpServlet.java:790)
	at com.inductiveautomation.ignition.gateway.bootstrap.MapServlet.service(MapServlet.java:85)
	at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:837)
	at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:583)
	at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:143)
	at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:548)
	at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:226)
	at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1160)
	at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:511)
	at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:185)
	at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1092)
	at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:141)
	at org.eclipse.jetty.server.handler.HandlerList.handle(HandlerList.java:52)
	at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:134)
	at org.eclipse.jetty.server.Server.handle(Server.java:518)
	at org.eclipse.jetty.server.HttpChannel.handle(HttpChannel.java:308)
	at org.eclipse.jetty.server.HttpConnection.onFillable(HttpConnection.java:244)
	at org.eclipse.jetty.io.AbstractConnection$ReadCallback.succeeded(AbstractConnection.java:273)
	at org.eclipse.jetty.io.FillInterest.fillable(FillInterest.java:95)
	at org.eclipse.jetty.io.ssl.SslConnection.onFillable(SslConnection.java:186)
	at org.eclipse.jetty.io.SelectChannelEndPoint$2.run(SelectChannelEndPoint.java:93)
	at org.eclipse.jetty.util.thread.strategy.ExecuteProduceConsume.produceAndRun(ExecuteProduceConsume.java:246)
	at org.eclipse.jetty.util.thread.strategy.ExecuteProduceConsume.run(ExecuteProduceConsume.java:156)
	at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:654)
	at org.eclipse.jetty.util.thread.QueuedThreadPool$3.run(QueuedThreadPool.java:572)
	at java.lang.Thread.run(null)
Ignition v7.9.10 (b2018112821)
Java: Oracle Corporation 1.8.0_181
There is a project property for general client-to-gateway response timeouts. You have to increase that one, too.
@pturmel, thanks for the feedback. The project property which looks to correlate to the issue I am seeing is actually OPC Browse Timeout. Were you thinking of something else? I’ll do some testing with it and report back.
No, the “Read Timeout” right above it.
