Hello,
I need to reuse a script from an ignition 7.9 project in my 8.1 project, and i found that “system.tag.scan”, i don’t really understand what does it do, and i am not very familiar with the 7.9 version.
I checked the doc to see how to use it in 8.1, but I didn’t find.
If someone knows what’s its equivalent in 8.1 or how I can replace it.
It has been deprecated,
https://docs.inductiveautomation.com/display/DEP/system.tag+deprecated
https://docs.inductiveautomation.com/display/DEP/system.tag.scan
Doesn’t always mean it won’t work though.
Perhaps show the entire script, maybe there is a better approach.
@jlandwerlen thank you,
I ended up with writing my own script, as i didn’t really understand the old one. Here is the part
(comments are in French)
this is a function in the project library
before this, setting some parrametres and updating some local tags
if row['Station'] == prmStation or row['Station'] == '*':
sColumns = sColumns + ", [" + row['Circuit'] + "], [Etat_" + row['Circuit'] + "], [Pcont_" + row['Circuit'] + "], [CodeDefaut_" + row['Circuit'] + "]"
##### ETAPE 14
system.tag.writeBlocking(sTagPathEtape,iRow*100+14)
sPathTagMesures = "["+ prmEdgeWare +"_"+ prmOP +"_default]MESURES"+ prmStation + "/" +row['Circuit']
if prmOP=="XXXX" :
if row['Circuit'] == "XX" :
sPathTagMesures = "["+ prmEdgeWare +"_"+ prmOP +"_default]M1/" +row['Circuit']
##### ETAPE 15
system.tag.writeBlocking(sTagPathEtape,iRow*100+15)
# Récupération des infos du test
system.tag.scan(prmEdgeWare+"_"+ prmOP +"_default", "scModules")
#iNProg = system.tag.readBlocking(sPathTagM + "/NumProg")[0].value
fFu = system.tag.readBlocking(sPathTagM + "/Mesure")[0].value
sFu = str(fFuite)
sE = str(system.tag.readBlocking(sPathTagMesures + "/Etat")[0].value)
sPrn = str(system.tag.readBlocking(sPathTagMesures + "/PCont")[0].value)
sCD = str(system.tag.readBlocking(sPathTagMesures + "/CodeDefaut")[0].value)
logger.info(sPathTagMesures+"=" +sFu+"/"+sE+"/"+sPrn+"/"+sCD)
##### ETAPE 15
after, updating some other local tags
@Kevin.Herron thank you , i’ll try with it.
Does the SPC module have something to do with this function.
