System.Tag.Toggle?
Hi All,
Hoping someone could advise on whether there is any sort of ‘system.tag.toggle’ function that exists, similar to system.tag.write ? Basically, i want to write a tag to ‘1’ and then back to ‘0’ a second or two after via the script editor on the button.
Below is how I am currently accomplishing it, but i don’t believe this is best practice. If anyone could advise a better solution it would be appreciated.
Many Thanks
Try this (this is ‘real’ toggle):
system.tag.write("MYTAG_1", not system.tag.read("MYTAG_1").value)
Hi @zxcslo - that is a really useful negate function, however, we need to write from 0 to 1, and then from 1 to 0, all in one button click. Sort of like what a momentary pushbutton would do. I might explore the ‘invoke later’ function.
InvokeLater will execute the function after the defined time.
You can probably do something like :
import time
system.tag.write('[Testing]Trial.value', 1)
# sleep(timeInSecond)
time.sleep(1)
system.tag.write('[Testing]Trial.value', 0)
if this is used more often :
create a function and just pass the tagPath to the function.
Thanks for sharing this! We want about a 3 second delay before resetting it, so InvokeLater might be the solution. I have saved this example code for future use though.
Cheers.
Yes, you'll want to use invokeLater--not sleep--for the second write, as in this example:
Super. Thanks for sharing this.
