having an issue where the system[currentdatetime] is off by 1 hour compared to local time on the server.
I have restarted the gateway with no effect.
server is in central time, but when running the project all my times on reports or on screens are all off by 1 hour.
Any suggestions?
thanks
Look in your ignition.conf file for any java timezone override.
i opened that file from C:\Program Files\Inductive Automation\Ignition\data but nothing in there about timezone?
Ok. Any timezone override in the project settings?
not sure where to look for that?
thanks for helping smile:
there is nothing in the project related to timezone? Am I missing something?
thanks
Wrong link. Access from the designer:
https://docs.inductiveautomation.com/display/DOC80/Vision+Project+Properties
Look at the “Vision General Properties”
Thank you , thank you, that was the issue.
