System.util.execute on Linux Client
Ultimately I need to be able to call a telnet session from a Perspective button, however I am unable to get ANYTHING to execute.
system.util.execute(["/bin/bash","/home/user/trancollector.sh","shell=true"])
#system.util.execute(["x-terminal-emulator"])
#system.util.execute(["/usr/bin/x-terminal-emulator"])
#system.util.execute(["xterm"])
Every attempt ends with:
java.io.IOException: java.io.IOException: Cannot run program “/bin/bash”: CreateProcess error=2, The system cannot find the file specified
What am I missing?? Only see the error on Designer, Client just acts as thought there is no script on the button. (Yes same PC).
This isn't going to work through a web browser. You're using a browser or perspective workstation because it might work with that?
According to the manual Perspective is in scope. I will try the Perspective Workstation.
Syntax
system.util.execute(commands)
  • Parameters
String[] commands - A list containing the command (1st entry) and associated arguments (remaining entries) to execute.
  • Returns
nothing
  • Scope
Gateway, Vision Client, Perspective Session
system.util.execute does work on the gateway scope, where Perspective scripts run, but keep in mind that’s the gateway scope - so your execute call is happening on the gateway, not locally to your clients. Also, your Ignition service is likely running with a different PATH than you have in a standard logon session.
