When I run system.util.execute([“C:\windows\system32\cmd.exe”,"/C",“start”,“C:\Users\Nick Ruimveld\Documents\Hello.bat”]), this is what is shown:
This is what’s inside the batch file:
echo off
title Hello World!
:: See the title at the top.
echo Test file executed.
echo I am too lazy to write commands again and again.
pause
Backslashes need to be escaped with, of all things, a backslash
system.util.execute(["C:\\windows\\system32\\cmd.exe","/C","start","C:\\Users\\Nick Ruimveld\\Documents\\Hello.bat"])
Python is also pretty forgiving on paths using forward slashes:
system.util.execute(["C:/windows/system32/cmd.exe","/C","start","C:/Users/Nick Ruimveld/Documents/Hello.bat"])
Just curious, how would you deal with files that have space in them?
I know you can put double quotations around the file name if you’re actually in cmd.exe in windows:
C:\users\userName\Desktop\"name name.jpg"
and it works just fine but how would you do that if you are running system.util.execute() in Ignition?
I tried to squeez the double quotation in there but didn’t like it, kept openning
C:\users\userName\Downloads
asking for a friend
You should be able to swap the quotes around, eg use single quotes around the Python character sequence, which will then pass unmodified (including double quotes) to the execute function:
system.util.execute(['cmd.exe', '"C:\Users\username\Desktop\some long file name.jpg"'])
Thanks for the quick reply @paul-griffith
I tried your way and it wouldn’t even open the cmd. It doesn’t like the ‘cmd.exe’ by itself, I had to use: 'C:/windows/system32/cmd.exe','/C','start'
for it to even do anything and even after that still opens:
C:\users\userName\Downloads (when done in designer)
and
C:\windows\system32 (when done in client)
Even if I only point the path to Desktop but the moment i take away either the double quotes or single quotes it opens the Desktop just fine.
Any other suggestions?
Close
Here's one that worked for me.
system.util.execute(['cmd.exe', '/C', 'C:/Users/username/Desktop/some long file name.jpg'])
No double quotes should be needed.
EDIT: If you are trying to open a file, then 'start' shouldn't be needed, either.
question, maybe I'm doing something wrong but I only have this in my actionperformed code and it still won't open cmd.exe:
system.util.execute(['cmd.exe'])
when I do notepad instead of cmd it will open notepad but cmd doesn't work for some reason.
cmd closes after execution. run start from the cmd to open a window.
system.util.execute(['C:/windows/system32/cmd.exe','/C','start'])
To start in your user profile:
system.util.execute(['C:/windows/system32/cmd.exe','/C', 'start /d %USERPROFILE%'])
