Hi everyone, I am a shell execute noob. I am trying to run an execute from Ignition to pass a string of 2 numbers into an excel file. in particular this script which i’ve run :
excel.exe /e "c:\Book5.xlsm" /p "3,1"
I’ve tried
commands = ['excel.exe',"C:\Book5.xlsm /p 3,1"]
system.util.execute(commands)
commands = ['excel.exe /e "c:\Book5.xlsm" /p "3,1"']
Typically I get an error saying specified file is unable to be found. Any help on this issue would be appreciated!
Backslashes are escapes in python quoted strings. Try doubling them up. Or just switch them to forward slashes.
Thanks for the help. I tried but oddly I’m not even able to open an excel file using this:
commands = ['excel.exe' , "C:\\Book5.xlsm"]
I tried doing some sanity checks using .txt files as shown on the Ignition manual for system.util.execute and they passed, however whenever trying to open excel file I get:
File "<event:actionPerformed>", line 11, in <module>
java.io.IOException: java.io.IOException: Cannot run program "excel.exe": CreateProcess error=2, The system cannot find the file specified
caused by IOException: Cannot run program "excel.exe": CreateProcess error=2, The system cannot find the file specified
caused by IOException: CreateProcess error=2, The system cannot find the file specified
You may need to put the full path to excel in there.
Thanks guys, both of these solutions were helpful!
