v8.1.0rc1
UPDATE: it seems I have a misunderstanding of json structures… working on it
I’m trying to make a function for development when we don’t have a PLC to convert all tags from opc to memory, as all the opc tag info is safely captured regardless of what data type it is.
I’m trying to make use of the clipboard and the Copy Json function in the tag browser context menu.
When I jsonDecode my clipboard tag json, it sort of works, but it only seems to be converting the root objects to python dicts, and leaves the nested ones as unicode strings…
This is my code so far (not finished):
from java.awt.datatransfer import StringSelection
from java.awt.datatransfer import Clipboard
from java.awt import Toolkit
from java.awt.datatransfer import DataFlavor
def setup():
global toolkit
global clipboard
toolkit = Toolkit.getDefaultToolkit()
clipboard = toolkit.getSystemClipboard()
def readText():
setup()
contents = clipboard.getContents(None)
return contents.getTransferData(DataFlavor.stringFlavor)
json = readText()
json = system.util.jsonDecode(json)
print json
print 'converting...'
def convertToOPC(obj):
print 'obj = ', obj, type(obj)
if isinstance(obj,dict):
print ' is dict'
for key in obj:
print 'key = ', key
if key == "opcItemPath":
obj["valueSource"] = 'opc'
if isinstance(key, dict):
print 'key is dict'
obj[key] = convertToOPC(key)
else:
pass
#if obj == "opcItemPath":
# obj["valueSource"] = 'opc'
return obj
for key in json.keys():
json[key] = convertToOPC(key)
print json
This is my test tag json:
"readOnly": false,
"dataType": "Int4",
"writePermissions": {
"type": "AllOf",
"securityLevels": []
"name": "_TEST",
"readPermissions": {
"type": "AllOf",
"tagGroup": "Default",
"parameters": {
"Unit": {
"dataType": "String",
"value": ""
"TagPrefix": {
"value": ""
"Format": {
"value": "#,##0.0"
"PLCName": {
"dataType": "Integer",
"value": {
"bindType": "parameter",
"binding": "{PLCName}"
"Description": {
"value": ""
"Global.": {
"value": ""
"tagType": "UdtType",
"enabled": true,
"tags": [
"opcItemPath": {
"binding": "ns\u003d1;s\u003d[{PLCName}]{Global.}{TagPrefix}.Avail"
"valueSource": "memory",
"readOnly": false,
"dataType": "Boolean",
"type": "AllOf",
"name": "Available",
"type": "AllOf",
"enabled": true,
"tagType": "AtomicTag",
"opcServer": "Ignition OPC-UA Server"
"opcItemPath": {
"binding": "ns\u003d1;s\u003d[{PLCName}]{Global.}{TagPrefix}.ResetPB"
"readOnly": false,
"type": "AllOf",
"name": "Alarm Reset CMD",
"type": "AllOf",
"enabled": true,
And this is the resulting print statements from within the convert function only:
converting...
obj = tagGroup <type 'unicode'>
obj = dataType <type 'unicode'>
obj = writePermissions <type 'unicode'>
obj = readOnly <type 'unicode'>
obj = enabled <type 'unicode'>
obj = tags <type 'unicode'>
obj = readPermissions <type 'unicode'>
obj = name <type 'unicode'>
obj = tagType <type 'unicode'>
obj = parameters <type 'unicode'>
