Good morning,
I would like to remove the box shadow of the tab container; I see inspecting it that the default grey color should be made in this lines:
.ia_tabContainerComponent__tab--modern--active {
font-weight: 500;
color: var(--neutral-90);
box-shadow: inset 0 -3px var(--border);
So i create a new style and insert the code under “background image” to make a test and change the color to white but it doesn’t work:
} ia.container.tab { box_shadow: #ffffff } {
Could you help me please?
I’m not seeing a shadow when I drop a tab container onto a view. (Ignition 8.1.16.) Can you post a cropped screengrab?
Ok course, here you are the picture.
I add the white rectangle adding the styles of the active tab as in picture attached.
You omitted to mention that you were using menuType : modern although I might have spotted it from the CSS.
Try adding
props.tabstyle.active.box-shadow : none
the selector and the property are not copied correct from the line you posted above xd also proabbly needs !important
} .ia_tabContainerComponent__tab--modern--active { box-shadow: inset 0 -3px #ffffff !important } {
If I was trying to get rid of the shadow using the color property I’d make it transparent - #ffffff00.
You can use box-shadow: none !important to make it dissapear, seems like he wanted it to be white idk.
There’s a difference between transparent and none, which is akin to the difference between props.meta.visible and props.position.display. I.e. none removes the box-shadow altogether whereas transparent uses processing power to “display” an invisible colour
Thanks guys for all your help. I apologize for not to be very clear in the explanation.
In the end using } .ia_tabContainerComponent__tab--modern--active { box-shadow: none } {
it works properly.. the only things is that in the designer I don't see the exaclty preview (even in preview mode), but if i launch it with F12 or with the app it looks correct.
Thank you very much for your time
