Good morning, maybe this is a stupid question, but I can't understand how to set a class style in the tab container properties, in particular in the active, inactive and disabled.
The style -> classes properties is not present and if I try to add manually I can't make it work.
Thank you for the help
It's working for me on 8.1.41 without difficulty.
My procedure:
- Hit the + Add Object Member button.
- Select
value from the dropdown.
- Type
classes and press Enter.
Now the dropdown arrow should appear and you can select classes as normal.
Thank you for your help.
I didn't try to add directly classes, I added style and then classes.
Have a nice day
