Tab Strip Hidden Function
Hi All,
I am using Ignition Version 8.0.14.
My Question is How to Trigger “Hidden” (True/False) Tab Strip Function based on the Tag while opening the popup?
Thanks in Advance,
Suresh
Hi, if i get it straight you are trying to hide a tab based on a tag value.
The tab strip component has a Property called Tab Data (which is a dataset).
You can bind this property with a cell update.
In this example i bound the Hidden tab of the first row to a tag called Hidden Tab :
Hope it will help.
Thank you. It is working perfectly.
