I have two windows, and a tab strip on both to enable navigating between them. Right now, when i click on the tab strip in A to go to B, and then click on the tab strip in B to go back to A, A's tab strip still shows window B selected. How can I make A's tab strip update?
Use only 1 tab strip in a main docked window, such as a header or sidebar. If I'm reading this correctly it sounds like you have 2 different tab strips for each window.
Thanks!
It is also important to know that the tab strip's built-in navigation also expects ALL main window navigation to use .swapTo(), not any form of .openWindow(), so there is never more than one main window open. Break this rule and the current window highlighting will break.
Good point. This would also cause an issue with your menu buttons not appearing to work because they would try to open a window that may already be open in the background
