Tab width in gateway script editor
I recently updating to 8.1.44 and I noticed that tabs in the gateway script editor are now 3 spaces wide instead of 4. Is there a way to change this back to 4?
I know this doesn't technically affect the functionality of the code, and I can always change the tabs to spaces in an external editor, but I'd rather not have to take the extra steps if I don't have to.
Note: this also affects the session events script editor, but not the project library, component script configuration, component event configuration script editors.
Did you happen to zoom in or out (ctrl + mousewheel) in this particular editor? Are you on a 'fractional' scaling display device (i.e is your monitor set to 125% or 150% GUI scaling)?
It looks like I altered the zoom on the editor without realizing it. After fiddling with it, I was able to get the indent to 4 spaces again. Thank you!
