I am unable to get my Vision Property Editor to display the information in the video. I am after the TestData but other sections are missing too. I have tried on the samplequickstart and a new project with the same results. default, sample_tags and system Tags are all running from ignition.
I don't believe it's anything that complicated as it's test data after all which should be ready to go for testing but never the less I'm unable to replicate the results as shown in the video. Any help and suggestions would be much appreciated.
This is a screenshot from Scripting In Ignition / Component Extension Functions:
This is a screenshot from my Ignition Designer:
What video?
Regarding the short properties list, you appear to have the "Basic" filter turned on. Expert or All will give you the TestData option.
Note that the checkbox is reset automatically once the test data loads.
So simple, I do recall this in one of the earlier videos now you've highlighted it. Specifically I was watching the "Scripting In Ignition / Component Extension Functions" but I believe the table settings which you demonstrated appear in multiple videos. Thank you.
I'm glad to help.
A few tips on using the forum:
- When you get a solution to your question there's a "Solution" button below the post that solved the problem. This marks it solved in the main index.
- If you're referencing an article or video then post the link. (They've launched a new documentation system this week so many of the old links on the forum are dead.)
- If you're posting code then please have a look at Wiki - how to post code on this forum.
Have fun!
