Table Binding Query Error Exception
I have an existing named query (MyQuery) that is successfully set up and outputting 2 rows and 16 columns when I test it in the named query testing area. I then go to view, add a table component, bind the data, and go to query.
From here, I am able to successfully select the named query, but an Error_Exception populates. It says that the named query is not found. I don’t know what to do here as the query clearly exists and is successful when I test it.
Save your query, oddly enough you can select it even though you haven’t saved it, but it will not work.
Silly mistake, but that worked - thanks!
