I have just been told of a weird issue when using the “save” button on an easy chart or have a save to CSV script to save a tables data.
When the Windows popup appears to allow you to name the file and select a folder to save it to, pressing the backspace key when focus is in the file name area will both delete a text character and jump up a folder level at the same time?
I have tried this on a couple of different clients and PC’s and looks like it might be a windows 7 issue as an XP box had no issue…
Has this been raised before?
Running 7.6.3 on Windows server 2008 R2
Cheers
EDIT: I found the issue still presented itself on another XP box…
