Table column visible error
Here's how I configured it
Then I select ID visible False, column_3 is gone. ID is last :smiling_face_with_tear:
I don't understand. Shouldn't the ID be hidden :face_with_diagonal_mouth:
I set the width to 0. ok :hear_no_evil:
what does your dataset look like?
It looks like the field property for your 3rd column should be "Operation", not "column_3"
edit: Wait, that's a new screenshot...
Just make sure the field corresponds to the actual column's name.
This is updated
columns:
        "field": "ID",
        "visible": false,
        "field": "Name",
        "visible": true,
        "field": "column_3",
        "visible": true,
        "viewPath": "Page/Edit",
        "header": {
            titel: "Operation"
See Wiki - how to post code on this forum. You will then be able to preserve indentation and apply syntax highlighting.
Case matters. Name is not the same as name.
This is the normal configuration, I think the sorting icon shows the configuration is correct
    "field": "ID",
    "visible": true,
    "editable": false,
    "render": "auto",
    "justify": "auto",
    "align": "center",
    "resizable": true,
    "sortable": true,
    "sort": "none",
    "filter": {
      "enabled": false,
      "visible": "on-hover",
      "string": {
        "condition": "",
        "value": ""
      "number": {
        "condition": "",
        "value": ""
      "boolean": {
        "condition": ""
      "date": {
        "condition": "",
        "value": ""
    "viewPath": "",
    "viewParams": {},
    "boolean": "checkbox",
    "number": "value",
    "progressBar": {
      "max": 100,
      "min": 0,
      "bar": {
        "color": "",
        "style": {
          "classes": ""
      "track": {
        "color": "",
        "style": {
          "classes": ""
      "value": {
        "enabled": true,
        "format": "0,0.##",
        "justify": "center",
        "style": {
          "classes": ""
    "toggleSwitch": {
      "color": {
        "selected": "",
        "unselected": ""
    "nullFormat": {
      "includeNullStrings": false,
      "strict": false,
      "nullFormatValue": ""
    "numberFormat": "0,0.##",
    "dateFormat": "MM/DD/YYYY",
    "width": "",
    "strictWidth": false,
    "header": {
      "title": "",
      "justify": "left",
      "align": "center",
      "style": {
        "classes": ""
    "footer": {
      "title": "",
      "justify": "left",
      "align": "center",
      "style": {
        "classes": ""
    "style": {
      "classes": ""
    "field": "Name",
    "visible": true,
    "editable": false,
    "render": "auto",
    "justify": "auto",
    "align": "center",
    "resizable": true,
    "sortable": true,
    "sort": "none",
    "filter": {
      "enabled": false,
      "string": {
        "condition": "",
        "value": ""
      "number": {
        "condition": "",
        "value": ""
      "boolean": {
        "condition": ""
      "date": {
        "condition": "",
        "value": ""
    "viewPath": "",
    "viewParams": {},
    "number": "value",
    "progressBar": {
      "max": 100,
      "min": 0,
      "bar": {
        "color": "",
        "style": {
          "classes": ""
      "track": {
        "color": "",
        "style": {
          "classes": ""
      "value": {
        "enabled": true,
        "format": "0,0.##",
        "style": {
          "classes": ""
    "toggleSwitch": {
      "color": {
        "selected": "",
        "unselected": ""
    "nullFormat": {
      "strict": false,
    "width": "",
    "header": {
      "title": "",
      "justify": "left",
      "align": "center",
      "style": {
        "classes": ""
    "footer": {
      "title": "",
      "justify": "left",
      "align": "center",
      "style": {
        "classes": ""
    "style": {
      "classes": ""
    "visible": true,
    "editable": false,
    "render": "auto",
    "justify": "auto",
    "align": "center",
    "resizable": true,
    "sortable": true,
    "sort": "none",
    "filter": {
      "enabled": false,
      "string": {
        "condition": "",
        "value": ""
      "number": {
        "condition": "",
        "value": ""
      "boolean": {
        "condition": ""
      "date": {
        "condition": "",
        "value": ""
    "viewPath": "Page/Master/Button/Edit_Button",
    "viewParams": {},
    "number": "value",
    "progressBar": {
      "max": 100,
      "min": 0,
      "bar": {
        "color": "",
        "style": {
          "classes": ""
      "track": {
        "color": "",
        "style": {
          "classes": ""
      "value": {
        "enabled": true,
        "format": "0,0.##",
        "style": {
          "classes": ""
    "toggleSwitch": {
      "color": {
        "selected": "",
        "unselected": ""
    "nullFormat": {
      "strict": false,
    "width": "",
    "header": {
      "title": "",
      "justify": "left",
      "align": "center",
      "style": {
        "classes": ""
    "footer": {
      "title": "",
      "justify": "left",
      "align": "center",
      "style": {
        "classes": ""
    "style": {
      "classes": ""
If ID is Visible false, it becomes Name, ID? :hear_no_evil: :face_with_diagonal_mouth:
So I had to design it this way :rofl:
