Table component crash with custom cell views
I'm having troubles with the table component while rendering multiple "events" in a table cell.
I have a table with columns that use an embedded view. That embedded view accepts an array of objects in its `value` view param. This data is then passed to embedded views in a flex repeater.
Every now and then the whole Table crashes with a react error (see logs below). The most annoying part is that it does happen sporadically (1 in 20 change when opening the view).
My question then is, why does this happen and is there way fix this?
Ignition version: Ignition standard 8.3.3 (b2026012009)
Logs (browser):
10:44:44.892 [Browser Thread: 166766de-cd4d-4df4-8cf6-47aa318f2c4c] ERROR Perspective.Designer.Workspace -- level: LEVEL_ERROR
message: "Error: Minified React error #31; visit Minified React error #31 – React for the full message or use the non-minified dev environment for full errors and additional helpful warnings."
line_number: 121
source: "http://localhost/res/perspective/js/react-dom-18.2.0.js"
message: "ui.ErrorBoundary: Component error caught in error boundary: {"componentStack":"\n at A (http://localhost/res/perspective/js/PerspectiveComponents.7504e0469ae1584669f1.js:2:1461933)\n at div\n at t.Content (http://localhost/res/perspective/js/PerspectiveComponents.7504e0469ae1584669f1.js:2:678640)\n at div\n at t.Cell (http://localhost/res/perspective/js/PerspectiveComponents.7504e0469ae1584669f1.js:2:678169)\n at div\n at z (http://localhost/res/perspective/js/PerspectiveComponents.7504e0469ae1584669f1.js:2:680562)\n at div\n at O (http://localhost/res/perspective/js/PerspectiveComponents.7504e0469ae1584669f1.js:2:684891)\n at t (http://localhost/res/perspective/js/PerspectiveComponents.7504e0469ae1584669f1.js:2:380824)\n at div\n at div\n at t (http://localhost/res/perspective/js/PerspectiveComponents.7504e0469ae1584669f1.js:2:388247)\n at A (http://localhost/res/perspective/js/PerspectiveComponents.7504e0469ae1584669f1.js:2:700513)\n at div\n at g (http://localhost/res/perspective/js/PerspectiveComponents.7504e0469ae1584669f1.js:2:687954)\n at div\n at g (http://localhost/res/perspective/js/PerspectiveComponents.7504e0469ae1584669f1.js:2:656548)\n at div\n at div\n at j (http://localhost/res/perspective/js/PerspectiveComponents.7504e0469ae1584669f1.js:2:1475572)\n at l (http://localhost/res/perspective/js/PerspectiveClient.5ad6074170c920d80c72.js:2:738350)\n at n (http://localhost/res/perspective/js/PerspectiveClient.5ad6074170c920d80c72.js:2:508988)\n at x (http://localhost/res/perspective/js/PerspectiveDesigner.04cf813f93fcbd579e01.js:2:157174)\n at (http://localhost/res/perspective/js/PerspectiveDesigner.04cf813f93fcbd579e01.js:2:131665)\n at div\n at h (http://localhost/res/perspective/js/PerspectiveDesignerComponents.c651d1ad9e4596f1ef6c.js:2:160425)\n at l (http://localhost/res/perspective/js/PerspectiveClient.5ad6074170c920d80c72.js:2:738350)\n at n (http://localhost/res/perspective/js/PerspectiveClient.5ad6074170c920d80c72.js:2:508988)\n at x (http://localhost/res/perspective/js/PerspectiveDesigner.04cf813f93fcbd579e01.js:2:157174)\n at (http://localhost/res/perspective/js/PerspectiveDesigner.04cf813f93fcbd579e01.js:2:131665)\n at L (http://localhost/res/perspective/js/PerspectiveClient.5ad6074170c920d80c72.js:2:352958)\n at div\n at t (http://localhost/res/perspective/js/PerspectiveDesigner.04cf813f93fcbd579e01.js:2:31627)\n at div\n at P (http://localhost/res/perspective/js/PerspectiveDesigner.04cf813f93fcbd579e01.js:2:298640)\n at div\n at o (http://localhost/res/perspective/js/PerspectiveDesigner.04cf813f93fcbd579e01.js:2:60161)"}"
line_number: 2
source: "http://localhost/res/perspective/js/PerspectiveClient.5ad6074170c920d80c72.js"
log the data passed to your subview/cell, so you can check what it looks like when you encounter the error.
The expanded react error is:
Objects are not valid as a React child (found: object with keys {completedAt, updatedBy, dueDate, leanWiki, description, scheduleGroupName, type, equipmentId, dueDateWithTolerance, responsible, name, dutyId, id, scheduleGroupId, completedBy, startDate, updatedAt}). If you meant to render a collection of children, use an array instead.
I'm guessing there's a branch in the code that generates the data that produces a dict instead of a list of dicts in some cases.
I also thought that this is the problem, and tried to explicitly set such malformed data in the table.data property. Sadly however this does not crash the table.
I noticed that there are multiple concurrent updates happening to the property. This may cause the issue, especially since i saw a different error related to building the property tree in the javascript component. I debounced these updates so they don't happen as frequently anymore and the problem seems to be resolved with that.
