Kudos
to Travis for adding the Foreground Color Column property to the Table component in 7.2.6. It saved me from a “can’t get there from here” situation. A natural extension to this would be to add foreground color mapping property (row-based in addition to the new column-based) to the table component. The existing Background Color Mapping by row would be the template for this new property.
You can obviously use the new column foreground color control for each item in the row to get the desired effect, which I did, but with a row property it would make it handier.
-Thanks again Travis!
