Table configuration with 3 different history binding
Hello,
I want to make a table with time stamp and 3 different history binding in 3 different column. I bind the data to the table config data but I can not see all the columns I want on the table just the last one I assigned.
I bind all 3 history tag on the data like below;
I want to have a table like below;
But this is what I get time stamp looks weird and there is 1 column of data the last binded one not all 3 of them
Looking forward for advise
BR,
Berkay
Hi @berkay.cinar, you will need to configure the props.columns property in the table to match what you want to display.
Have a play, but if you need further help in configuring this, post back here and we can work through it together :slight_smile:
Hello Matthew,
I got it to work adding to the columns property, thanks.
