When binding a table to a query and selecting a return format of json it returns a very simple object as opposed to what’s eluded to in the manual (i.e. a dictionary with keys value, editable and style). In my attempts to transform the simple json I’ve run into a couple of issues:
If the query returns a null, the value displayed in the table is a string representing the whole dictionary. If I put a value in the db table, it returns what’s expected.
The order of the columns returned doesn’t seem to be that of the query. The following script transforms a returned dataset to a list of dicts. but the column order is different than what’s expected. If I set the return format to json, the column order is correct.
# convert incoming dataset to a list of dict
editableCols = []
ds = value
colNames = ds.getColumnNames()
d = []
for i in range(ds.rowCount):
rowDict = {}
for col in colNames:
editable = False
if col in editableCols:
editable = True
rowDict[col] = {"value":ds.getValueAt(i,col),"editable":editable}
d.append(rowDict)
return d
