Is tere a property for this? The ‘results’
I would like to bind that to a status bar like this:
Currently it shows the full table listing, I would like to bind the 300 to the filter results which would be 69 in this case.
Add an expression binding:
len({../Table.props.filter.results.data})
Your path will most likely be different, use the property selector to get the correct path.
Your question is a little unclear but I think you are asking how to get the number of results returned by the Perspective table component’s filter function. Try this:
props.filter.enabled : true.props.filter.results.enabled : true.len({this.props.filter.results.data}).
