Table Padding on Row Not Working as Expected
Working on a table an noticed the header was not aligned with the tables contents. Followed the thread listed below. Ran into an issue with how the row selection looks.
When a row is selected, I noticed the selection is shifted creating a gap. Visually, not a fan of this. But the tex position is good.
marginLeft fixed the tex.
Decided I need to pad the content. But this has 0 effect.
Setting I applied.
I might be needing to set padding on a different object or should the Padding Left be working? Thoughts?
If you launch the view in a browser you can use Developer Tools (F12) to examine the CSS. Hit the inspect button (top left) and select the item to be examined. Here's what I got:
On the table header:
.table-container .t .thc .content {padding: 5px;}
On a table row:
.table-container .t .tc .content {padding: 0px;}
On the selected row:
If I understand your question properly, the solution is to modify the tc padding by overwriting it in the advanced stylesheet. Add these two lines:
.table-container .t .tc .content {padding: 5px;}
Save and reload the page in the browser. (You may need a Ctrl+F5 to force a reload of the CSS file.
The result.
You should be able to do this directly in the component and not use the stylesheet. I've always done this (mostly within a style class, but same thing). Not sure why it's not working for the OP
Not sure either. Hence the question. Seems like it should be easy to fix. Will give the styling sheet a try.
@Transistor I noticed your solution shows the same thing twice. Was one supposed to be ".thc"?
I set a domID:
Referenced it in the "stylesheet":
Solution (proper spacing):
