Table Props Pager Params: selectedOption?, optionsIndex?
Hello,
Within the Pager property params, I don’t see any params for options such as: ‘selectedOption’ or ‘optionIndex’.
Is there any way to access the values for said example param(s) or any workarounds to get the value(s) when the user changes the selected ‘option’ while using the table?
For example, is there a way to access either the selected value [10] or the selected index [1]? Or if the user chooses 25 rows in the dropdown the values would be [25] and/or [2] respectively?
Thanks in advance
On Ignition 8.1.13 the pager dropdown doesn’t even appear for some reason. I can’t think how I could have turned it off.
@Sean_Tesch
HI, you have any solution on this ?
I also need to access this value but not able to grab it from anywhere :no_mouth:
Unfortunately not.
