Hi!
Is there a way to disable a Table to switch to three dots when you click in a cell?
For example, I have a table like this.
When i click inside the cell with 3 it changes to this.
I’d like to disable that, is that possible?
The 3 dots indicates the column is too narrow to display the text. If you make the columns a bit wider it might be ok.
No that is not the case here.
