I am trying to figure out what to put in the version key to get my row to change colors
i made a row and changed all the fills on it to red and named it Idle Row
this is what i was trying to put in the version key, ive tried many many variants but i cannot seem to find out what is wrong
allstatus is a key that just shows the status of the machine , I want it so if the machine is Idle it will change to the Idle fill color
@allstatus@=“Idle”?“Idle Row”:“Standard”
any ideas where i am going wrong?
Well I have no idea what you actually tried, so I can’t tell you what’s wrong.
But If I understood correctly, you want to color table rows dynamically, based on a status. Is that status specified in each row ? Does you table have a status column ?
Psst! Be sure to tell us you’re using the reporting module.
Try using ==.
yeppers , I have a status column and the key for that column is @allstatus@
and it created a status in each row next to the timestamp it was made
T_stamp Status
so it will be like
7:00AM Idle
7:01AM Idle
7:02AM Off
and i was trying to get it so if it says Idle then the whole row is a certain color but if it says Off its a different color
I am using the reporting module!!
I have tried many various combinations in that version key spot and none of them work
some examples are
@allstatus=“Idle”?“Idle Row”:“Standard”@
@allstatus@=Idle?“Idle Row”:“Standard”
allstatus=Idle?“Idle Row”:“Standard”
@allstatus@==“Idle”?“Idle Row”:“Standard”
and so on and so forth , im not sure if its because idle needs to be in “” (or doesnt need to be in “”) or if because the key doesnt need @ or does need @ , theres a lot of factors that could be making it not work
Should be allstatus=="Idle"?"Idle Row":"Standard"
Be sure that the spelling is correct, no extra spaces, etc. Been caught by that once or twice.
You almost certainly do not want a keychain expression in the version key field.
You would just put allstatus in your version key field, then make a row version named "Idle Row".
