Can you specify table schema like this in a transaction group?
This group is full of hour meters. If I stop and start the group, it will read initial values from the table like I expect, but then when it executes it doesn’t (seem to) write the new values out to the table. Has anybody seen a problem like this?
Yes, there is a checkbox under the advanced section of the DB connection page on the gateway, don’t recall what it is called but it will expose the schema should the option be checked.
The problem wasn’t related to the schema name. The problem was that the default index column didn’t exist. When I changed the transaction group to use a custom index, everything worked as expected.
