The table setSelectedColumn script exhibits unusual behavior. If I have a “cell edited” script and within that script have the line "setSelectedColumn(7) and then edit column 1, when I press “enter” the next column selected is, correctly, column 7. Same for columns 2-6. However, if I am editing column 7 and press enter, the next column chosen is not 7 but rather 8 in violation of the setSelectedColumn(7) command.
This behavior is causing me a problem in a “cell edited” event where I am monitoring the data being entered to make sure it is in range. If it isn’t in range, I pop up a message box informing the operator of the error and then have the script select the column they just entered so they can try again. I can’t get it to happen. I can select any other column but not the one they just edited.
Version 7.5.8
