If I have a table with 2 columns one column is an “ID” and one is “NAME”.
This table is populated with a dynamic dataset, which only returns the ID and NAME.
When I click on the NAME how do I read the ID value for that name?
I want to use the ID to populate another dataset but can’t make my query because I don’t know how to
pass the ID value
In the example above, the 0 would be your column number in the dataset. I’m not sure if your using a power table, regular table or what their called but this should be a starting point. I would also wrap it in a try so you can force a value into it if nothing is found.
I’d create a custom property on the table to do this.
OK, I just about have this all working together but can’t get pass this part.
In the insertnote function of the “comment panel” I need to take the “Table 1.ValueID” and apply it to this variable ID=Table 1.ValueID
I’m assumming it has something to do with the scope of Table 1.Value because if I use this
ID=7 or any of my numbers to represent the Inventory ID of the table it will work.
The Table 1.Value is from an expression and is a CUSTOM Property of Table 1
