My issue is, the use can pick a product from a drop down, a dataset is built and put into a table with a hidden column to indicate the row item was found. I have background color map based on that found column and the found column is always correct.
The first drop down selection the color works, second it does not, third it does, and forth it does not and the pattern continues.
This is the table’s column attributes data:
This is the table’s customizer:
Why do they only agree half the time?
