Tabs showing the same data
I have created a Perspective View for 2 cooling towers with tabs to switch back and forth between the tower displays. However, when I click both tabs are showing the same tower data. I'm sure the solution to this is fairly simple, but I am new to Perspective. Any suggestions?
Tower 1
Tower 2
This is a question directly from the certification test. The certification test is a measure of your skill, not other people's skill. The test clearly lists what resources you are allowed to use, which are the user manual, Inductive University, and emailing the training department. Anything else results in an automatic fail.
