Hi, I’m setting up an alarm for a parameter change, so I’m using “Any Change” mode. Is there a way to use Active Delay to ignore the alarm when the value changes for a second and then returns to the previous value? I believe the Active Delay currently works on other modes except for the “Any Change” mode
I am having the same situation, not sure whether you already got the right answer.
